New carb kits (2), new plugs, new water pump kit, new fuel pump kit, new fuel lines/primer bulb, new gas. Compression 115 on all 3.<br /><br />I cannot get the dang thing to idle. I have worked those idle screws (in water) every which way and cannot get the thing to idle. I have to use the warm-up lever (which revs it) then QUICKLY pull it down and put in gear to get it to do, otherwise, it dies.<br /><br />Also, once I get going, it will go for a while, then die and not start unless I squirt starter fluid in the carbs (I know not to do this, but it was the ONLY way I could get back to shore, so I had too!). <br /><br />After warming up, as soon as I put the warming lever back down....dies. No amount of adjusting on the idle screws/mixture screws works. <br /><br />I replaced the floats, needles, gaskets on the carbs. I don't see anyway to "adjust" the floats. Is there a way? I just put the new float in the bowl...didn't see a way to adjust anything as far as the float.<br /><br />Any suggestions are appreciated. U can also email me w/suggestions at sfarrisrn@aol.com. Thanks!
