Suspect my 1996 90 SPL non VRO may be going into limp mode because it is getting hot. I get NO beep (only had boat a short time and didn't know about this) when I first turn the key on A forum member recommended I test the sensors. I disconnected each of the brown plugs coming off the head and grounded them on wire leading back to control box. Turned key on and nothing. I disconnected the horn and applied 12v and horn works fine.
Where / what else can I check? On the engine wiring loom there is a black and brown female plug at the bottom that has nothing plugged into it and I can't find anything that will plug into it (maybe left by factory for VRO equipped).
