need some info from the oracle
slasmith1
I was wondering which drives I have the boat is in the water and I was going to replace the annodes when I pull it out for another repair. 2000 model 5.7 duo prop ist it the dps? (volvo)
1) SN 4012015675 Spec #3869059
2) SN 4012015671 Spec #3869059
here is a photo from the last haul out if it helps.
Don S
Re: need some info from the oracle
Yes, It's a DP-S.
Here's the maintenance chart for those drives.
attachment.php
HT32BSX115
Nice,
That boat must run pretty good with the Dual-Duo's!
slasmith1
Nice,
3100rpm 26knt @ 12gph or
4600 rpm 47knts @ 63gph :eek:
the boat is 36 loa weighs about 16500 as rigged and handles like a runabout.
and does that make me just down the hill from Orting?
slasmith1
Don the part number for the AL anode for the transom assy. comes up as a fuel filter. any other ideas?
HT32BSX115
If you're keeping that boat in the water on in Tacoma, with all that SS in the water, do you have an electronic system to control galvanic corrosion?
Don S
http://www.volvopentastore.com/Tran...*****.073386756--store_id.366--view_id.324996
PS: Those serial numbers you gave were for the engines. When I looked them up, neither one was ever registered with Volvo. So there was no way except to go with the EF engines for the drive models. Not a big deal though just thought I would pass the information along.
That parts chart actually came from the Volvo site.
The link above is from here at iboats.
slasmith1
No I have been considering installing one but I haven't been able to get a clear answer if I need to install one on each drive with twin applications.
I am switching back to al annodes I have been told that with the stainless props it is a better choice.
I have not had a corrosion problem on the drives but I do seem to go through zincs pretty fast. I will see how it does with the al.
slasmith1
Don since we are discussing anodes here I hate to quote myself but would I need a seperate unit for each drive using the ql active corrosion protection system that is sold on iboats(volvo)site or would they have a bad interaction with each other in which case I should just stick with the al anodes?
Don S
Let me see if I can find some more information on them before you start ordering things. Do you have a link to the one you found here?
