I have an older Bass Tracker 17 that we just got back in the water after a long time. We have some issues with the tilt and trim on the Johnson 50 HP motor and are just trying to get by until we can adress that over the winter. Since I can raise the motor with the trim what hole should I have the pin for that in. Currently it is in the second hole out from the transom and the boat won't come up on plane before the prop starts to cavatate. If we move the pin to the third or fourth hole out will that help it to plane even though I understand that it will effect the Hole Shot, I am not really concerned about that as long as I can get on plane with out the caveatting. This is the same setup that did great several years ago so what can I do in the short term?
