Need Spark Plugs
jambon1
What Plugs can I use in my 2003 VP 4.3 GL? I was hoping to go down to the local Autozone and pick up some replacement plugs for Volvo part #3861632
Thanks in advance
four winns 214
Re: Need Spark Plugs
Have you removed the old plugs already? My V-P came with AC plugs as original equipment (it's a GM engine). I just took one down to the local NAPPA and they fixed me right up.
nitwhit
An 03 should be a Vortec. If so, you'll need the longer threaded AC MR43LT. The MR43T's are for the pre-Vortec heads. NGK also makes a suitable equivalent in a marine rated plug as well. I don't know if Autozone carries them but a NAPA or Oreillys/Advance Auto should be able to fix you up.
