Ok,
So I finally took the boat out and got to really run it. With it loaded up, coolers and all that other crap, I got it up to 50.1 with GPS. This was just with me and the wife on it, for the run and all our gear.
The boat is a 94 Crownline 196BR with a 5.0 Mercruiser (2 barrel carb) and Alpha 1 drive with 1.65R gears, stated on the Lower Unit.
The guy that I purchased it from said that it would go 64, which was hard to believe with the prop that was on the boat. We did have it up to 59 for the test run, with flat water, there was not a single wave in site, as it was like 8am on a Saturday alot cooler, about 50 degrees that morning.
When I ran it yesterday, I got it up to 50.1 with the two of us and it was a bit choppy not smooth. The RPMS got up to 5200 rpm, which I think is to high for the 5.0 Mercrusier that I have.
I also had My bimini top mounted on the boat and it was up, not open, but sticking up on the supports. I also did not have the Front bow cover on front of the boat as we did in the morning that I had taken the boat for the test drive.
I could only trim to about Half Trim, or just below half, before the Prop really came loose and my rpms would shoot up.
The prop is a 21 pitch, I know, Not sure on the diameter though. I will try to find this out. It is an aluminum prop.
Does anyone have any ideas what I should have on this boat?
Thanks for all the help.
I have used the Hustler props in the past with really good results, from the Aluminum. The prop on the boat is a Michigan wheel prop, which I never really liked in the past.
Bryan
Bryan
