Well, I found out the hard way that my 1992 Chaparral with 4.3 Yamaha (which I read is not worth a wooden nickel due to no parts) has a bad impeller. Did not run very hot and only for about 1 minute. But, where online can I buy new thermo and impeller. The impeller is for a Sherwood pump and is stamped with #6. The pump housing is a G3 cast. Impeller is 1.25" long with a 5/8" bore and a 3/16" key. <br />Thermostat is made by Robertshaw Controls and is stamped 21 L9 0143. Motor normally runs at 145 degrees in all conditions. <br />Where can I buy these online, or can I? Dealer wants too much.<br /><br />Thanks in advance.<br />David Martin
