before i bring out the mega sledge hammer is there a tip to removing the elbow fromt the exhaust manifold?
I did remove the bolts![]()
You should avoid prying them apart as you can bugger the mating surfaces, there is not a lot of steel there....it is a 5.7 350 merc.
i ended up using a small prybar and put it between the elbow and exhaut manifold and separating....slowly.
