10 FOOT INVADER
- Joined
- Apr 29, 2007
- 94
My problem is that I have a 2003 merc 25hp long shaft that needs to fit on a 10 foot gw invader. Transom height is around 17". The transom at the top is 17" wide but tapers down to 10" at the bottom for the motor. The mini jacker is 17" wide. Can I cut the lower portion of the mini jacker off? Also I looked at the hi jacker Looks like it could be bolted with the 2 parts together than use a spacer at the top to mount the out board clamps and then bolt the bottom. Any ideas? With the plate a bout 5" below the bottom of the boat she will hit about 20-25mph but the rpms will only hit around 4200. The motor does run very well at that rpm just eats a lot of fuel. Thanks
