Need to now if these Yamaha Pt #'s will work, asap...
pfistey1
I would like to know if these two part numbers will work on my 2002 90hp 2 stroke.<br /><br />1). 6Y5-8300-T1-00 Multi-Tachometer<br />2). 6Y5-83500-A0-00 Multi-Speedometer - I'm pretty sure this speedo will work.<br /><br />Your help is greatly appreciated....
bigbrownbuku
Re: Need to now if these Yamaha Pt #'s will work, asap...
yes and yes. read the attached green cards carefully and set the dipswitches accordingly.
pfistey1
Thank you, for my understanding, what do you mean, when you say attached green cards?
rodbolt
the instructions for proper tach and speedo set up are on the cards.<br />ya gotta set some dip switches.
pfistey1
Rodbolt, if I don't have the cards, what would my options be? Thanks.
rodbolt
to ask someone to look for them. I have them about someplace. and they are in the rigging guide. may be in the technical guide.
pfistey1
Thanks rodbolt, any possibility of maybe you finding them? Or, can suggest where I can locate & purchase the rigging guide or the technical guide. I have neither. Thanks again.
rodbolt
hello<br /> your tach dip switch settings should be 1 on, 2 off, and 3 on., that will read 2 wire trim 12 pole alt and 2 stroke.<br /> the speedo for mph will be 1 off or down,2 on or up,3 off or down and 4 on or up. that will set for MPH and and 30-230 ohm fuel sender. the european and yamaha senders set differently and you can set the speed to km/h or knots/h
