Re: Need To Pull Flywheel On Swedish 4HP Outboard
hi i bought the same motor last weekend, and had the same problem.i used two large spanners either side of the fly wheel and hit the bolt with a hammer after two or three wacks it poped off, the engine is a crescent 4 hp idenitcal to yours i cleaned the contacts and the magnets and off she went, not bad for a 40 year old. points were set at the distance that the off set cam on the fly wheel approx 1.5 mm
good luck with yours all the way from sunny England Dave
