GUYS,
I asked a question about removing a brokem manual relief screw a few days ago. I have 87 merc 150. The tilt/trim relief screw broke and have to remove it. The hole that allows access to the screw will not allow me to pull screw through it. I was told there was a e-clip on the screw but there is a big plastic looking washer that looks to be permanently attached to screw in the front around the head area of the screw. This prevents me from pulling screw thru the access hole. Its almost the same size as the access hole. I was thinking of maybe getting a rotary grinder and opening it up just a little bit to remove screw. any suggestions here or should i do this. thanks for help
