Need to replace Fuel Sending Unit
Status
Not open for further replies.
Chado339
I have a 1988 Chaparral 198 c xl. The fuel sending unit is gone and I need to replace it. I pulled the old one. It was made by Medallion Instruments Inc. It appears the model number is B-1321. It is 240 ohm. Medallion no longer makes this product and I can not find what replaces it. If someone could give me a hand that would be great. Thanks - Chad. I have attached a picture of it.
Re: Need to replace Fuel Sending Unit
Ayuh,... Just get a universal fit 240ohm unit...
1KnoxArmor$
can be repaired,depends on patients, mechanical ability.i took mine apart very carefully,lifted plastic cover off,on the inner end of swing arm is what looks like a brass ball spring loaded,took the swing arm out very cafefully,used some P320 x fine paper,polished end of ball carefully,put back together, checked reading with multi meter,Success.
Status
