Need water tube from pump to motor.
beach
I was working on my 82 9.8E Mercury LS. When I removed the lower unit to replace the impeller I found that the tube from the water pump to the motor is missing. Where can I find a replacement?
andrewkafp
Re: Need water tube from pump to motor.
Are you sure it's not there ? The motor will not last 5 minutes with no tube. It is a very thin diameter pipe that runs next to the drive shaft and will detach from the water pump but stay in the leg when the L/U is removed. Does it run ?
beach
I'm not asking if you believe it's gone. It's not there, period. I'm trying to locate a replacement.
beach
Can I just make one with a piece of soft roll copper tubing? Looks like 3/8" maybe.
Merc805
How did you end up with an assembled motor with no tube ?<br />You couldn't have tested it, as it would have no water flow. <br />I think that is why we are asking the question.. Are you sure it's not there ? And if not WTF is it ?<br />You may be able to make one, but make sure it is sealed and don't forget to install it this time :D :D :eek: <br /><br />32 - 39062 TUBE, WATER (LONG SHAFT) 1 $53.20 <br />From http://www.dougrussell.com/partscat...x.cfm?fuseaction=serials&colid=01&coldesc=9.8
beach
I purchased the motor a month ago, fired it up in a tank before purchase and thought maybe just needed an impeller. When I started re-assembling is when I noticed it wasn't there. Maybe the previous owner lost, damaged or who knows what with it. I was finally able to make a replacement with copper tubing, fits snug so should be OK.
beach
Any chance I can find a battery for this motor?
