need wiring diagram 1992 70 force
roscoe
Re: need wiring diagram 1992 70 force
HAve it, but in a manual, no scanner.
What exactly do you need to wire up.
Can easily tell you the color codes of the parts/wires you need.
mobdick10
tks.,roscoe im putting in new igniton sw. with push choke 6 pronged,been restoring this boat, the sw. was gone when i got it. tks., for any help. i've replaced the trigger,voltage reg.,sw. on motor and now ign.sw.,painted topside ,new carpet, i also have speedo and tech,voltage gages would like to install them too :confused: if u could help with those too:rolleyes:
roscoe
ignition switch.
terminal id --- wire color(s)
B red and red or red/purple stripe (2 wires)
S yellow or yellow/red stripe
C green or yellow/black stripe
M white and white or black/yellow stripe (2 wires)
M blue and blue or blue/black stripe (2 wires)
I red/blue stripe
