Hey Folks,
Looking to build my own swim platform extension on my Doral Br185. Essentially I am looking to build a platform similar to what is found on dedicated wakeboard boats. The purpose would be to be able to stand on the platform to strap into our wakeboards.
My idea is to go with 2 "L" brackets to secure the platform to the boat, I am thinking of building the platform in a semi circle shape with the width being approx. 6 feet and having it extend maybe 20 inches behind the boat. I plan on building the frame out of steel, my uncle is a master welder and plans on builfing it out of steel approx 3/8 inch think and maybe 4 inches wide, then I will cover the frame with composite deck board.
What I need from you guys is you opinion on whether or not this can work, also, what technique would you use to bolt the platform to the boat and what type of sealer should be used where the holes are drilled as well as where and how much of this sealant should be applied.
Fire off your ideas, opinions and comments!
Thanks
Thanks
