Ok - In another thread about fiberglassing some questions came up and there was a suggestion to start one asking for help - here it is:
The below pictures give you a BEFORE and AFTER perspective - the boat had some wood rot in it - I stripped it down to just the stringers which appear to be in good health. I want to restore the boat back to its original layout. My question is:
How would you do it?
My questions are as follows:
1) The thickness of the fiberglass appears to be about.25" -
a) Is that one thick cloth that has resin on it?
b) Are there different types of cloth?
c) If so which should I use?
2) The wood that forms the support and decking Appears to be about 0.5" in thickness -
a) It looks like plywood is that correct?
b) Is it a special type?
3) The Grey surface in the boat -
a) What is that - paint?
b) Special type?
c) Where do I buy it?
4) The Foam that I removed -
a) Where do I buy it?
So my plan is to:
- Make templates from cardboard
- Use resin and cloth at the bottom (of the boat), place the wood on top to create a water proof seal (rather than wood to the base of the boat)
- Place all the wood in place in the same manner to create a waterproof seal.
- In the cavities, spray foam and cut the excess before placing top pieces.
- Secure top pieces and glass in place.
- Glass over top of the wood decking to the boat (sides) - creating a bond of the two as well as finishing of the boat.
Am I on the right track?
WHEN PURCHASED:
TODAY:
b) Special type?
So my plan is to:
WHEN PURCHASED:
TODAY:
