Needed 2003 Polar Kraft Owner Manual
phabej
I just bought a used 2003 Polar Kraft boat with 50 HP Yamaha 2 stroke motor and there is no owner manual with it. I'm new to this boat and don't know much about it. I've google online but found nothing. Does anyone know where I can get a copy of the owner's manual?
smokeonthewater
Boat owners manuals, unlike car manuals, are VERY generic and contain pretty much no usefull information about the boat. Whatever you need to know about the boat simply ask here.
Bob_VT
Probably the best suggestion is to make sure you have an owners/maintenance manual for the motor. As mentioned above - ask anything on iboats. Yep, boat manuals show which side of buoys to pass and wear a PFD.
phabej
How does the live well works? Does water automatically fill up when boat is in the water? Or do you have to turn on a switch to pump water in? Also, how do you drain it afterward?
smokeonthewater
Generally there is a pump to fill the live well and a stand pipe in the live well that drains it from the surface so it doesn't overflow.
On some boats you pull the stand pipe out to drain it, on others there is a plug you remove and on others there is a valve, often having a remote lever near the helm.
Do some poking around and post some pics of your setup and we can help more.
