Re: Needed badly! 2007 4.3 merc parts
New isn't a problem. Even aftermarket power steering pumps are $400.00. As far as the elbows go, there is a new one here in B.C. and one in Fondalac Wis. $289.00 ea. I am looking on C.L. and Ebay. Anyway, thanks for your input.
Ayuh,... It's Possible to match up the pump with a GM part, but I don't know which 1...
The ports, 'n mountin' points are 'bout the only things that change 'tween applications on those saginaw pumps...
The coolers can be found here, 'n there,...
the low pressure return hoses, ya cut off a spool...
The hi-pressure hoses gotta match the pump, 'n actuator... custom, from a Hose Shop can over come some issues there...
Brackets, you can make,...
Pulleys ya gotta buy, or find used..
