NEEDED: Torque Specs 1993 175 Mercury connecting rod bearings
Faztbullet
Re: NEEDED: Torque Specs 1993 175 Mercury connecting rod bearings
If it a 2.5 175 see below....
1st Torque - 15 lb-in
(1.5 Nm.)
2nd Torque - 20 lb-ft
(27 Nm.) Turn bolt
additional 90 degrees
after 2nd
torque
emckelvy
Be sure to renew the rod bolts, these should be of the 'stretch' type and once torqued are permanently deformed. If you use old bolts they'll break and that tend to ruin one's day!!!
HTH.........ed
