needing instructions rebuilding my carbs 1985 115hp johnson
licketdsplit756
got the kits in for the carbs without any instructions. anyone have a diagram ya can e-mail me ldschall@yahoo.com would appreciate it. this will be my first attemt. want to do it right.it cant be all that bad. ive read in here where to soak over night in carb cleaner. blow out all orfice's. are there any tricks or tweeks that i can do or should do while its apart. ty model j115tlcos
Silvertip
Re: needing instructions rebuilding my carbs 1985 115hp johnson
Instructions are as close as your library. Check out a service manual. What "tricks" or "tweaks" are you referring to? For what purpose? If those carbs have idle mixture screws, before you remove them, turn them all the way in counting the exact number of turns. Write that down and then set them the same way when you reassemble the carbs. You need to do that for each carb since they will likely be different. If you have already been messing with them, you will need to reset them properly when you are done.
licketdsplit756
i dont have the manual it hasent arrived yet. is there a stock setting for the jets. 1/half turns out or something like that not sure if they were messed with before i bought it.
ezeke
Thanks JB​
licketdsplit756
ezeke ya hit it right on. that is my carb. ty for the video.that was great help. thought i was looking at a all day job. he made it look simple. ty again.
ezeke
Thanks JB
