Needing Tuneup Specs
flyingd
I have a 1969 starchief V with the 4 cylinder 120 hp in it. Can you tell me the timing, dwell, point and plug gap? and would the timing be different boating at 4000 - 5000 plus feet. I found a serial number on a plate, 2647628. the cast stamped numbers are 0915983, E 28, CON 2.
anything else that would help with a tune would be great too
thanks for all the help
slicksboat
Re: Needing Tuneup Specs
timming no if the boat has been around your area and worked before then you need not to worry about but jets in the carb are sized acordingly to elevation so if its from a way lower elevation you need to change the jets in carb points can be set to the thickness of a match book cover which is about .020 and spec is .022 plug gap is .035 dwell is 28-34 degrees and timing is 6 degrees btdc whats going on that you need a tune up has it got a hesitaion hard start or just checking things out
ziggy
the oem service manual has some facts in them. ya can find them here. specially mercruiser if that's what ya got?
flyingd
The boat has been maintained its whole life in this area so the jets should be good. It has been hesitating and missing. I looked at the cap, rotor and plugs and they were not good. put new cap rotor and plugs in and it runs much better. But didn't have the specs for the plugs and points so this will be a great help. Thanks
slicksboat
well if you decide to rebuild carb let me know i just did mine no hesitation no stumble my rpm is supposed to be 650 to 700 and i pur at 625 i can go lower if i want to but it starts to lobb like its got a cam and no rich idle as that carb tends to do there are tricks and contact me before you buy the kit cause the serria kit isnt the one you want and theres things that arnt out there that you need to know oh and the cab is super simple you can do it and be proud that you did
