Neewbie With alot of questions.....
Redneck101
I Just purchased a 15' 150 Sierra Starline w/mercruiser mcm120. I have never owned an inboard/ outboard before. I took it to the lake saturday, It ran great for about Ten minutes then started to slow down and smoke out of engine compartment. I babied it back and trailered it. I found oil leaks getting on block causing smoke. No big deal this i can fix. but i do need a new carb due to engine cover sitting on spark arrestor and breaking carb housing. but the question i have is when i went to drain block, I pulled bleeders and block was as dry as a bone! Would this be a waterpump issue or what and where is the water pump????? and if the block got hot enough to slow boat down did i possibly crack a block. I checked the oil its good but with no water in block IDK!!
Re: Neewbie With alot of questions.....
Ayuh,... Welcome Aboard Redneck,... That don't sounds to good...
Head on up to the Adults Only section at the top of this forum,...
In there, you'll find a Gold mine of information about your I/O,.. Including the factory manuals,...
You'll probably need #1, but you don't state a vintage...
The raw water pump is mounted on the top of the lower unit,..
You need to split the lower unit from the Upper to get at it...
Good Luck,....
Redneck101
Sorry its a 1987 model. I downloaded the #10 manual last night as well as Anything I could Find on a mercruiser 120. i just havent had a chance to read through it all.
ziggy
#6 for the drive.
I have a lot to learn...
Ayuh,... From your vantage point, it's a pretty Steep curve,...;)
Is that an ole GMC in your avatar,..?? Neat ole truck...
Redneck101
1964 gmc 4000 dumptruck cab on a 1982 school bus chassis with 2 66 chevy beds grafted together with a 94 cummins 12 valve diesel and 6" stacks. The Beast. one of my other "Toys" and thank you.
cr2k
When you drained the block; did you poke around in the drain holes with a nail or something? I would bet if you didn't you will find some rust and crud blocking the drain holes. Always got to probe for water.
Redneck101
I did try to probe with small screwdriver. but all i got was rust.
Ayuh, How Deep did you get,.... Should be about an Inch or so deep...
starsnstripers
Yeah i've had those holes block up pretty good. Make sure you probe all around and work all that rust out. Maybe a metal coat hanger and get it to go into the water jacket a ways.
