Hello,
I have an EZ Load Trailer single axle. GVWR 3000# for DMV. I have a bent axle which is resulting in negative camber (more on the left wheel) I was reading but can't find the answer I am looking for. I was thinking, would flipping the axle, which is 2" square), would this help getting it back somewhat strait? The wheels are perfect without the boat on it and I only drive 1.5 miles down the road to put in. Additionally, after reading I am confused about mounting the axle over or under the leaf springs. It is currently mounting on top with two square u bolts. I am not sure this is correct. I think it should be under.
Thanks,
Sal
P.S. When I say flip, I mean, rotating the axle 180 degrees so the side facing down will then face up.
Thanks,
Sal
