Re: NEMA Cable thru Rigging Tube Advice
Pez any problems or concern with the fuel line in there? How'd you get the NEMA end thru the gromet? So instead of a quick deal Friday evening and then fishing on Saturday I probably need all day Saturday
Yes, I was concerned with damaging the fuel line, and anything else in there. I bent the end of my SS wire into a very small loop so that I did not introduce a sharp, pointy thing into the tube. If by grommet, you're talking about the rubber bushing/clamp pictured under the engine cowling (click to enlarge), I just disassembled it and went from there. I did this some time ago so I don't remember all of the specifics. Getting the wire through is just the beginning. Maneuvering the NMEA cable through is always the hard part. Now I used a Raymarine "stripped end spur cable" to pass through the rigging tube, before I spliced it to a Yamaha "pigtail bus." Your Lowrance cable may have a connector which poses and even bigger problem, but where there's a will, there's a way.
