Evinrude_NooB
- Joined
- Jul 21, 2011
- 142
I bought an old Neptune WC-1 Mightly Mite. It was sort of working and I began to tinker and restore it. I'm having two issues and I'm hoping some seasoned people here can help with some advice.
1 - I cannot get the motor to start if I put the prop all the way in the water. What I mean is that it will start and run if the prop is out of the water or if it's just 2 inches in the water. In other words, it would not start in a normal running situation mounted on a transom. It seems as though the load is too much for it to start. So what I've been doing to test is start it up in shallow and then put it down about 6 inches of water.
2 - It seems to run a little hot and I'm wonder if it's cooling properly or if the exhaust is plugged.
Any advice is greatly appreciated. Thank you.
