Neutral Problem
Taz59
1995 3ltr LX
Goes into forward & reverse gear ok but when going back into neutral it sometimes still in drive.
What adjustments do I need to make & where.
Cheers
Col
nuboat2me
Re: Neutral Problem
SOunds like a shift interrupt switch problem. DO forum search for SHift Itnerrupt. there is a great thread that spells it our and it has pictures!!! :)
I am fighting that little "Feature" now...
I replaced the lower shift cable, measured and adjusted to the 6 inch mark.
Shift interrupt is still killing the engine. My SI wire to the coil was cut by the PO to "Eliminate" the stalling issue.
Good luck!!
