Neutral Safety Switch Dual Control
csauer454
Hello. I have an 1989 Sea Ray 340EC with two inboards and a Morse dual shift control. The neutral safety switch appears to be failing on the starboard control lever, and I need to jiggle the control lever between forward and reverse to find a sweet spot. It is getting worse. Does anyone know if the unit contains a neutral safely module and is serviceable, or would the entire dual control unit need to be replaced? Thank you
Ayuh,.... Welcome Aboard,..... I gotta believe the switch is replaceable,.... Findin' a new 1 might be tough,... donno,...
