HI<br />I TOOK MY BOAT OUT THIS MORNING AND AFTER SOME TIME ON THE WATER I THREW THE ANCHOR TO CHILL AT THE BEACH. WHEN I RETURNED AND TRIED TO CRANK THE BOAT, NOTHING HAPPENED. I FIGURED IT WAS PROBABLY SOMETHING WITH THE NEUTRAL SAFTEY SWITCH SO I TOOK THE ENGINE COVER OFF OF MY 88 WELLCRAFT 4 CYLINDER AND MESSED WITH THE THROTTLE LINKAGE AND GOT THE BOAT TO START. IT SEEMS I HAD TO GET THE LINKAGE IN JUST THE RIGHT SPOT FOR THE ENGINE TO TURN OVER. DOES THIS NEED TO BE ADJUSTED OR WHAT NEEDS TO HAPPEN? ALSO, I'M NOT SURE IF THIS IS RELATED BUT WHEN I GOT BACK TO THE RAMP AND LOADED MY BOAT, I TURNED OFF THE IGNITION AND THE ENGINE DIDN'T TURN OFF. WHAT IS GOING ON. IS THIS RELATED OR DID I GET HIT WITH TWO THINGS AT ONCE. PLEASE HELP. <br />JOHN
