Re: New battery discharges quickly
Thanks Ralph. The battery seems OK: I have recharged it myself 3 times due to this problem of unknown discharging and each time I connect it to the charger(after noting it is dead/not staring motor or lighting lights) the charger amp meter starts out at just under @ 10 when I start the re- charging and ends at just above @ 0 right before I turn charger off. The battery then works to light lights, sound horn, run bilge pump, and start engine. I have only run the engine about 2 minutes since the problem started. And I notice the dead battery when I return to the boat and try the lights, etc. I have not been knowingly operating anything when the it stops working.<br /><br />An added point: I note lots of 1/4-3/8" pieces of styrofoam in bilge water well from under floor. I suspected bilge pump clog and maybe float switch held up by the styro bits, but haven't heard it running. After last fiddling with the pump and replacing the mechinally sloppy in-line fuse link from positive battery terminal to pump, the pump did seem to work fine.<br /><br />Hope that helps you narrow the possible problem. Looking forward to your thoughts.
