Hey Everyone,
I could really use some guidance.
I decided to abandon my restoration project and got myself a 1985 Chris Craft instead. I brought it home yesterday evening.
It runs great and everything, but the prop is in REALLY bad shape. I feel like it is unusable and I would feel nervous to take it out like this.
So... I need a new prop. I know pretty little about props and could use some help.
I have 2 questions: 1) Can I use this prop to take the boat out and test the RPMs? and 2) What would you recommend for a new prop in regards to the info below?
Using the sticky as a guide, here is what I am looking for and some information about my prop:
I need a prop that performs well for Wakeboarding. Wakeboarding/Watersports is most of what we do when we go boating. Good hole shot, hold speed well, etc.
It has a Mercury, 78116A45P15, Aluminum prop right now. I'm not sure if this is the original prop or not. It seems like it is has a low pitch for others I've seen on similar set ups...
15.25 X 15 P
I'm not sure. I just got the boat, so I am not certain of performance yet. I did Lake-Test the boat, but I'm still learning about all this boat stuff and didn't do a WOT test.
Mercruiser Alpha One (1.65:1), 1985, Chevy 305 5.0L, 200HP
1985 Chris Craft, Scorpion, 1985, 18'6, not sure of weight
1) Performance issue you are trying to correct.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
3) Current prop diameter and pitch (required).
15.25 X 15 P
4) Wide open throttle RPM and speed with an average load (very helpful)
5) Engine/drive make, model, year, and HP
6) Boat make model, year, length and weight
