I just purchased a 1989 Four Winns with a 4.3L OMC cobra. I ran it on a hose before I bought it and engine runs great, shifted fine, ran quiet in gear. However once I got it in the water, it has a pretty loud vibration in it, even in neutral. The whole hull of the boat is shaking. It gets worse when the trim is up and when turning, especially when accelerating. Is my gimbal bearing going out? If not what else can cause this?
I plan to replace the gimbal bearing myself if that is the problem, I have read about the alignment tools necessary to do this job. What exactly needs to be aligned, are you aligning the bearing with the drive shaft so it runs evenly in the bearing? Is there a good place to buy these tools? Anything else I should know before tackling this one?
Thanks for the help guys!
