New Boat Owner, need some direction!
bcorona1
Recently I purchased a 73 Richline Fiberglass Bass Charger (I think thats the model) It came with trailer as well as a 1969 Evinrude 25hp outboard motor (model # 25903b). We got the boat for 300 bucks, not a bad deal I dont think. We took the boat out the other day to make sure it was functional. When we purchased the boat we got the motor to turn, and the lady we bought it from said it hadnt been cranked since about last may. The hull seems strong, the transom seems solid. There is only one soft spot in the bow deck area. When we took it out on the lake to test her out, we couldnt keep the motor running strong. Supposedly the motor ran fine last year, and it has had fuel injector work and been re-wired and plugged. The motor is very clean, seemingly. I was curious as to what i should do in order to get this boat into fishing ready status. We have only invested about 300 into this boat and are just looking to get the boat in functioning shape, hopefully without breaking the bank. So as of now i think we are going to do a few things :
To Do List :
1) get motor to run smoothly
2) Re-deck the boat (temporarily)
3) Sand, Fill, Seal, and Re-paint Hull (minor scratches, and minor gouges)
Does this seem feasible for a boat project. As far as getting the motor to run better, i need some good direction. I am pretty handy and have worked on a few types of motors, just no outboards. As far as re-decking the boat. I was thinking about cutting into the original deck to make sure the stringers and foam are "structurally" sound and just decking over the original deck. I know that this is not a permanent fix, but we are not looking to keep this boat forever, we are just looking to fish on it for a few years. I know that we need to cut 1/2 plywood to shape, resin seal it, affix it to original deck, then glass into sides. Does this sound relatively accurate? With the hull, we need to sand it down, fill scrapes and scratches with "bondo" material, seal with resin or epoxy paint, and then sand and re-coat a few times. Does this sound feasible?
Like I said we have never owned a boat, but are looking to gain experience in boating as well as repair. We purchased the boat for 300 bucks and are not trying to break the bank to get to water ready. Any help would be greatly appreciated.
Here are some pictures of the boat:
JB
Re: New Boat Owner, need some direction!
Howdy bcorona1
Welcome to iboats. :)
The only part of your post that belongs here in the JohnnyRude Forum for outboard engine troubles is this:
"When we took it out on the lake to test her out, we couldnt keep the motor running strong. Supposedly the motor ran fine last year, and it has had fuel injector work and been re-wired and plugged. The motor is very clean, seemingly. I was curious as to what i should do in order to get this boat into fishing ready status."
The rest belongs in the Boat Forum. I suggest that you start a new thread here addressing your engine problem(s) and I will move this thread to the boat forum.
bcorona1
your right, and its my bad. I havent posted before and didnt realize where i was posting this. I had actually thought it was in the boat repair forum
Gary H NC
To get you started before you move to the Johnson-Evinrude section.
That motor is not fuel injected...just a basic carb that is probably in need of a good cleaning and rebuild.
After long periods of non-use the 2 stroke oil in the fuel will plug them up.
murphree
I totally agree with Gary H. Clean those carbs and introduce some fresh gas.
Home Cookin'
focus onthe motor; probably just needs carb cleaning and related service; update the fuel lines.
I wouldn't bother fixing up the boat; spend your time fishing/boating instead. At most, paint. IN other words, consider the time and money going into an old boat to end up with an old boat.
kriegersa
I think that boat is a piece of junk and you should sell it to me for $350 :) :p.
all kidding aside i would say a good carb clean should do the trick. but others have already said that.
bcorona1
I agree with all of you. I am going to take the carb off today when i get off work and clean it out, it was just re-done this past july, so hopefully the float, needle, and jets wont be in too bad shape. Then i am going to re-run the gas line and clean out the bulb and tank. I think that whoever was running this motor before i got it wasnt running the right gas/oil mix, or even using 2stroke oil. I found a half-empty motor oil quart in the storage of the boat. So hopefully after re-running the lines, cleaning the carb, and checking the lower unit she'll be running good enough to hit the lake and get to fishing.
We will more than likely just re-deck it and paint repaint the deck. The hull seems fine and isnt worth the hassel.
pmillar
Don't forget to drop some new spark plugs in there as well.
