Hello, I am a new boat owner(again) and now own my first inboard powered boat. I have some general questions I hope some experienced owners can answer. It is a 1982 Glastron 19.5 ft deck (SV191) with a 260 HP Merc. I would like some tips on what, if any, problems were common with these boats/engines/outdrives. I am unsure of the exact model outdrive I have, it just reads Mercruiser on it. Also, what kind of performance should be expected? I took it out for the first time today and was very impressed. I never tried to top it out, but it hit 40 without much effort and pulled a big tube like it wasnt even back there. Basically, what things should I check to make sure there are no probs, beyond the obvious? Also, do you check the gear oil in the outdrive by taking out the screw towards the top of the drive? It is labeled "L vent", not what I would expect on a lube level check screw. Sorry for so many questions, I will stop for now.
Thanks.
Thanks.
