New boater here!
trsimmons25
I just picked up an 84 Bayliner cuddy 19 ft with the Volvo AQ 125a and 270 outdrive. This boat had a cracked exhaust manifold that the previous owner had welded but did not reassemble. I could use some input on the cooling system. The tilt unit does not seem to be working (the switch has the wire ends cut off). This whole boat needs rewired! I would like any advice for maintanence like spark plugs oils etc. Can I use automotive grade parts or do I have to use marine grade? Thanks for any and all help!
NYBo
Re: New boater here!
Welcome to iboats!:cool:
Your questions about the motor and outdrive will be better answered if you post them in the Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives section.http://forums.iboats.com/forumdisplay.php?f=21
Wiring questions will be answered in the Electrics, Electronics and Trolling Motor section. Pay attention to the stickies at the top; there are several generic wiring diagrams there.
There are few automotive-grade parts that can be used. Anything that can create a spark (other than spark plugs) MUST be ignition-protected. This includes the starter and alternator. The distributor must also be a marine-grade unit to ensure it has the proper advance curve.
