new boater
normbelanger
I recently bought my first boat. 18' starcraft with 125 evinrude. Engine idles fine but won`t run at wide open throttle. Any ideas???
Red Snappa
Re: new boater
You might have the wrong prop. A lower pitch prop will run at a higher RPM.
ezeke
Re: new boater
Try cleaning the high speed jets on the carburetors.
kenmyfam
Re: new boater
Basic health check to begin with.
Compression
Spark
Fuel delivery
Spark plug condition
A good carb's service as ezeke suggested is a very probable issue.
Did you get a test ride in the outfit before you bought it ???
Did you do any checks on the motor before you bought it ??
Where in Ontario are you ??? anywhere near me ??? If so you can bring it over if necessary.
normbelanger
Re: new boater
compression-130psi
good spark
new fuel lines and spark plugs
I got the boat, motor and trailer for a grand. I think I got a good deal.
The boat is in great shape. The motor is a 1982 115hp o/b evinrude, run good up to about 2/3 throttle but misses at WOT.
