New Carburator on one year old boat
krnch
I have a 2004 17-foot bowrider with a 3.0L Volvo Penta stern drive. Since new it has exhibited a slight hesitation when you drop the throttle quickly (e.g., fast hole shot). I recently had an authorized dealer look into this when I had the boat in for a routine oil change. They advised me that my timing was off (about 6 degrees) and that the accelerator pump was flooding the engine under hard acceleration. They adjusted the timing and accelerator pump settings. They claimed that the idle mixture is fixed on my carb (Holley).<br /><br />When I water tested the boat, it ran terribly. I had trouble starting it and my previously small hesitation was now very big, almost stalling the engine. The top speed dropped from 44 MPH to 38 MPH and constant speeds were no longer constant as the boat would "chug" and vary speed slightly up and down when on plane.<br /><br />Annoyed, I took the boat back to the dealer. They had their most seasoned mechanic look at it who has advised me that the carb is faulty and I need a new one (under warranty). This is surprising to me as I always felt the boat ran fine, with the exception of the slight hesitation during acceleration. The dealer suggested that the timing and accelerator pump settings had been tweeked to try to overcome the defective carburator. Does this sound plausible?
salty87
Re: New Carburator on one year old boat
with as many ways a holley can be adjusted, i'd be surprised to see one where the idle screw couldn't be. i'm no carb expert but that sounds strange.
Mahoney
Most of these hesitations are a bit more involved than adjusting idle or even accelorator pump settings. It is usually due to a transition between an intermediate circuit(cruising off idle) and the primary or secondary circuit(going to wide open and running) There is a short time where the fuel feed tubes may not be primed in the secondary circuit and produce a quick hesitation while this happens.<br /><br />I have a Rochester and a great book about tuning them, and the fix for this is to actually drill small holes in the secondary fuel pick up tubes to feather the transition between the primary and secondary circuits. I decided the hesitations wasn't worth tinkering with this.
tommays
if you search through here on 3.0 its a common problem<br /><br />the new carbs have a fixed idle mixture screw thanks to the EPA the easyest way to adjust it is to get a replacment screw <br /><br />the timeing has to be set to specs or it will cause engine damage<br /><br />it seams like there trying to help you i can only suguest you let them try to fix it<br /><br />i have had mine so long 10 years that i really just learned to drive the boat in a way that it doesent happen<br /><br /><br />tommays
