New Carpet and Glue
LAKERJOE731
I bought carpet with marine backing for my 16 foot boat. Is it normally glued down? and if it is what type glue should I use?
Chris1956
Re: New Carpet and Glue
Joe, You can get outdoor carpet cement at Home Depot or a hardware store. It even comes in a latex which dries waterproof. Spread it with a notched trowel. If you find the carpet does not stick well to the verticle parts of the boat, use contact cement on these areas.
Realgun
The glue has the notch dimentions on the can. Get the cheap plastic 1 when your at the Hardware store. The reason is if you use a larger than recommended notch then glue can and will squeeze though the carpet.
