Re: New computer and cable modem questions
An integrated card just means that the card hardware is part of the motherboard and does not take up an i/o slot. You can get good integrated video or mediocre integrated video. Usuall, these boards will still have an AGP slot to add a better card down the road. I do play a lot of games, and in my opinion the Nvidia cards (geforce, etc) are the best, most compatible cards. Price is good for the most part too. I'm running a Geforce-4 440MX that's a few years old now and even the newest games like Unreal Tournament 2004 still run silky smooth on my Pentium 4 2.0Ghz. As a comparison, my work PC is a 2.4GHZ with an intel-based on-board video, and even with the faster processor the game runs 10X better on my home PC (but still good enough to pass the time at work LOL!). <br /><br />The cable modem is a separate piece of hardware, like a mini cable box for your PC. You can rent them, or buy them, whatever makes more sense at the time. <br /><br />Any home router should work. I use an old SMC Barricade, about $75 if I remember correctly years ago. You need a WAN router and not just a hub. A router will address whatever hardware you connect using DHCP, and will allow as many computers as you can stuff into your house to access the internet. You only need one router, then after that you can branch off using normal hubs (cheaper). For example, I have a 4-port router which connects to my cable modem. From this router 3 ports go to PC's and one port goes to a 24-port hub which has other hardware connected to it. As far as sharing the printer, all you need to do is set it up on one PC, then 'share' it to the other PC's connected via the network. No extra hardware/software needed. <br /><br />To network the laptop, you need to get an ethernet adapter, either for the PCMCIA slot or USB. Pretty straightforward.<br /><br />Hope this helps!
