new coupler or should I wait
finer things
I cant align motor I get it exact then turn motor 180 and its way off kept trying and I believe the coupler is bad so I am buying one on ebay .my question is do I keep old coupler and align as close as I can and then replace coupler and yoke when it goes bad
Fishermark
Re: new coupler or should I wait
That's a lot of work to pull the engine twice - not to mention the need to be towed in when the coupler goes out.
finer things
thats part of the problem didnt know coupler was bad till I was aligning the motor after it was in
Bluestream
Follow the procedure recommended by Mercruiser in their shop manual, and you will do fine
Ayuh,... If you'd rather spend 4th of July weekend doin' it,....
Sure,.... Roll the dice,... Run 'er......
