Hi Everyone,
I have a 73 Johnson 6hp. I've been having issues w for some time but it was usable till this spring. Early this year, I couldn't get it to start. I haven't tried till this past week to get it running. I went Sat. and bought new plugs, and an OEM Fuel Hose Assembly. I have had nothing but issues out of the hoses and fittings bought at Walmart or sporting goods stores.
I took the boat out Sat. and tried for about 5 min. of cranking and gave up. It never even hit. Yesterday I put the motor in the tank and tried again where I could work on and inspect things better. After about 10 cranks it hit, then started, then ran fine. I got the idle rich/lean adjusted and it was running well in the tank. I even ran it in drive as high as I felt was safe. Turned it off, started it right up several times, no issues. Ran all the fuel out the carb and let it sit for 3 hrs, hooked it back up and it started on first pull. So, it seems to be running ok now.
Here is my ?s:
1. I noticed fuel spitting out of the back side of the fuel pump. It is not a crack, but a perfectly square port of some sort and it was a consistent spit of a drop of fuel coming out. Is that normal or is there something wrong with the fuel pump or carb possibly? If I had to guess, I would say a cup of fuel would come out in about 5-10 min. of idle.
2. The past couple of years I've been trying to figure out why the motor surges at top rpm. It is not a miss, just a slow down followed by a gain and that repeats every 15-30 seconds. It is very possible it could be fuel hose assembly I was using. I will know more now that I can get the motor to start next time I take it out. But, I did notice yesterday when the motor was in the tank that the little black arm that meets the roller to control speed has a fairly deep groove worn in it. I would say the groove is probably a 1/8 inch deep. That doesn't sound like a bunch, but I reached in and pulled the lever back to where it would be if it were flat and there was a definite change in the rpms. Could this be what is causing the motor to not reach and stay at full rpm? Also, is that lever adjustable?
Thanks for any info you can provide!
Here is my ?s:
