Re: New Drive, first oil change.
The bottle is clear plastic. I put the 2 halfs together and installed on boat. I filled it with the Quicksilver gear lube which is the standard brown color.
When I put the upper and lower together, I did notice a blue/green grease on shaft. I was hoping I could get confirmation that they did the same on the inside giving me this color.
As the oil was draining, the it was streaked with green ( whatever that is ). just to be safe, I'll let it sit over night and see if it separates. The engine hasn't been on for about 3 weeks now so it should have separated. I didn't see a change in the drainage though.
