miktwalker
- Joined
- Jun 7, 2016
- 10
Hello out there. Need some advice for correct prop. New 5.7 300 HP (240HP here at 5000') with an Alpha One gen 2. Currently have a 14" 19P Stiletto 3 blade Stainless prop. With the new motor and Holley HP EFI system WOT average after 4 WOT trimmed runs yesterday is 5000 RPM. Measured by my laptop plugged into the ECU. Factory dash tack read 5200RPM . Original Mercruiser 5.7 210 HP 2 BBL manual says max WOT is 4200-4600. Prop shop recommends Solas 14" 19P 4 blade stainless should bring down RPM 200. Says 4700 RPM OK even though over max manual 4600 RPM. Engine builder says motor can take 6300 RPM. Questions are:
1. What is the limiting rpm factor Mercruiser publishes in their manuals? Engine? Drive? or combination considering the factory prop specs?
2. If I switch to a 4 blade prop (from the 3 I have now) should I go up in pitch to a 14 20 to bring the RPM down to 4600 (extra blade worth 200 RPM 1 inch pitch worth 200 RPM)?
3. With the extra HP upgrade, and going to a 4 blade 14 20P, would I be placing too much torque on the drive?
Thanks for reading my post. Looking for input.
