Re: New Engine
If the cam is New, Pull the coil wire,+ crank for 45 seconds to a minute... Start it on muffs,+ immediately rev to 1800/ 2000rpms, for atleast 1 minute... Return to idle,+ check + adjust the carb, timing, etc....<br />Now you're ready to start boating... The in-water break-in Should consist of 20hrs of near constant throttle changes.... Not to long at idle.. Very little time at WOT, although a little WOT will help you dial-in the prop, while you break-in...<br />Your 20hrs service Should change the oil, check All other fluids, Check for good color on the plugs, check the timing + carb adjustments...<br />At this point, You're ready to run this motor another 1500hrs, with service at every 50hrs(for me) to 100hrs(for people who think gas is the Only required fluid)......<br /><br />Good Luck...
