Re: New floor but no carpet
I am going to be putting a new deck in my boat this spring and want the carpet to go away with the old floor. I would like to gel coat the floor but have a few questions. What is the best way to texture the floor? What gel coat do you recommend? What is the best way to apply it? I have a quality spray gun but for base clear, will this work if the gel coat is thinned out?
Hello Pete..
First off..that Quality spray gun DO NOT use lol..dont want to chance kicking gel off in a good gun ( also the fluid nozzle and needle could probably shoot thinned out gel..but its way too small to shoot SAND through it ! ).
Second.. Use ONLY Grip-tex nonskid particles (
http://www.awlgrip.com/Product Datasheets/4078+A+eng+A4.pdf ) .. NOT sand. They have a variety of grits ( fine up to extra cource ). Sand will show when used over a period of time.
I like to use a 50/50 mix of fine and coarse. When mixing with a paint stick if you tip the stick at 45 deg and let the paint drain off the stick it will show how much and kinda what patern you have On the paint stick..adjust as needed for your taste..
Now your prep. You have to base color your deck Before you apply the non-skid ( spray or roll does not matter ). You Must have a prepped surface color before the application of the skid..if you "burn through" your base here and there..you have/should spot coat and reprep those areas before application.
Basically the way I do it is get the glassing done..then softpad/DA sand the glass smooth...then roll or spray the gel base color. Then I Prep the gel with 180 grit ( Its All one base color at this point and prepped ) wipe with acetone and then mix and roll/spray the Nonskid Gel/mix over that.
I personally think spraying turns out Alot better because you can shoot inconsistant spots here and there and even the pattern up.
Also..mix your Nonskid/gel mix with 25-30 % Patch Aid..not wax.. ( There are different forms of Patch Aid/booster available .. but I like CCP Patch Aid 970X900
Prep is Key before anything in your nonskid app ..
YD.
