Re: NEW FORD PICK UP
Hi,<br /><br />I have had some experience with automatic transmissions. 13 years as a Ford certified master automatic transmission technician. It has been my experience that coolers have a tendency to lower transmission temperatures there is two negatives. 1. Improperly installed, can cause a leak and transmission failure. 2. On newer vehicles with pcm (power train control module) controlled shifting if the transmission never reaches operation temperature it can have a negative affect fuel mileage. For pulling a trailer I have found that it is best to leave the vehicle out of overdrive when pulling any considerable load. The ideal is to prevent the transmission from shifting from one gear to another, locking and unlocking the torque converter, and creating heat.<br /><br />If you service your own transmission dont forget to drain the torque converter!<br /><br />Respectfully, bowhunter2
