New fuel gauge, reads half no matter how much fuel
Dave K.
Gentleman, ​I've been posting about my fuel gauge not working. After two new sending units with no change, I bought a new gauge.
Good news: The gauge has a reading
Bad news: It's reading half full no matter how much fuel is in the tank
Could this be a ground wire issue?
I'm tempted to put the original sending unit in as it's probably still good and the one in there now has a slightly different float arm
Thanks Dave
wahlejim
If it is a different style float, it doesn'thurt anything to change it out. It may by hitting the top of the tank and unable to give you a higher reading.
roffey
take this from where is coming as I am not that mechanical. What if you take the sending unit out and manually move the float up and down, see where the gauge reads or what it does?
ThomW
Have you tried grounding out the gauge to see if it spikes up to a full reading? If that works, then its a wiring issue or the float and/or arm in the tank is not set up right, or able to move properly in the tank.
Dave K.
I'm going to put the original sender back in. The arm on the new one is different. I have a feeling that could be the problem, I hope. I'll try the ground wire on the sender too.
Thanks for the responses
rallyart
Test the sending units outside the tank to see how they behave, with a wire to the sender and another to ground. ThomW's idea is a good one, also. The biggest problem I see is that it is a boat fuel gauge and must therefore be wrong. It is just a boat cult thing.
