new fuel sending unit won't fit in 1998 key west 1520
Nealnoname
Got an new unit from builder but it seems to be about .5 to.75 inches too long to fit in tank. Supplier said the #5 sending unit was the correct one and thinks my tank has sunk in the middle. Can I use longer screws to pull top of tank up to base of the sending unit and gasket? If I can, then I will replace the longer screws one at a time with the supplied screws. Has anyone had a similar problem?
tpenfield
Re: new fuel sending unit won't fit in 1998 key west 1520
Not the best idea in the world as you will have the fuel sender in contact with the bottom of the tank and begin to wear a hole in the bottom of the tank . . . possibly maybe.
Does your fuel tank look like it sank down in the middle????
If this is the tube type of sender, I believe that they can be shortened with a little custom modification. Alternately, you could do some research and get the next smaller tube, if it were a couple inches shorter.
Do you know which brand of sender it is (VDO maybe ?)
