I just installed a new fuse block, had corrosion issues with the old one, now I have power issues with the new fuse block.
If I turn my ignition key to ON, the voltage meter reads 12V. While the ignition ket set to ON and I turn on the anchor light, the voltage meter drops to 10V and the lights are dim. Next test, I turn the ignition key to OFF, turn the radio on (works fine) and then turn on the achor light. The light is dim but the radio is still running. Next, turn the radio off and turn on the anchor light. The light is very bright.
Could I have a bad wire from the circuit breaker to the fuse block? Bad ground wire? I cleaned the terminals at the circuit breaker, no change. I also noticed if I push on the terminal at the circuit breaker, the breaker pops. Could it be a bad circuit breaker?
Any suggestions?
Any suggestions?
