Re: New gas tank
I HAVE FACED YOUR PROBLEM ONCE OR TWICE. THE THINGS I LOOK AT WHEN POSITIONING GASOLINE FUEL TANK ARE AS FOLLOWS.<br /><br />SHOULD IT BE ABOVE OR BELOW DECK?<br />IT MUST BE HAVE A VENT TO FRESH AIR, CAN NOT SHARE A SPACE WITH A BATTERY OR SWITCHES(ESPECIALY STARTER CILINOID) AND SHOULD HAVE CHOCKS OR BATTONS SCREWED, AND GLUED TO THE DECK SO THE BUGGER CANT SLIDE,A BUNGEE OR SOMETHING OVER THE TOP CANT HURT.<br />IF YOU HAVE THE SPACE IN YOUR COCKPIT, YOU MIGHT CONSIDER ADDING A SHORT BULKHEAD, INBOARD OF YOUR TRANSOM. ELIVATE THE FUEL TANK A BIT SO WHEN THE LIMBER HOLES YOU BUILD INTO YOUR NEW BULKHEAD GET CLOGGED, THE TANK WILL BE LESS LIKELY TO FLOAT AWAY. <br />THATS THE HARD WAY, BUT IT CAN BE A BENCH SEAT, OR SPLASHWELL AND GOOD WET STORAGE. BUILD OFF YOUR TRANSOM AND DON'T MAKE HARD SEEMS ON YOUR FREEBOARD,THE BOAT NEEDS TO FLEX.<br />I DON'T LIKE FUEL TANKS FORWARD. EVEN 15GL, UNLESS IT'S BELOW DECKS, WELL VENTILATED, HAS A DECK FILL, AND A BLOWER, MY HUMBLE OPINION IS...BAD IDEA. PLUS YOU GOT THAT MUCH MORE FUEL LINE TO CRACK, PINCH, OR KICK, NEED I GO ON.<br />IGLOO COOLERS MAKE GREAT STORAGE COMPARTMENTS,CENTERED LONG WAYS, EITHER PARELLEL OR PERPINDICULAR TO THE STERN, GOOD CHOCKS, INSIDE AND OUT, 5200 AND LAG BOLTS IF NEEDED,PLUMB YOUR VENT, AND FUEL LINES AND YOUR DONE. MG
